plz help mercury sport drive 90hp compression with force block
Status
Not open for further replies.
Josh122593
What is piston compression supose to be on a mercury 90 hp sport jet 3 cylinder?I tested it today and it was top-125 middle-100 bottom-120.Greatly appreciate any help.
jim_b_20653
Re: plz help mercury sport drive 90hp compression with force block
125 is good. What is more inportant is that they should be equal. It sounds like you may have stuck rings. You should decarb, then restest the compression, hopefully the numbers will look a little better.
Josh122593
thanks do u use sea foam to decarb if not what do u use
JB
Duplicate post. See Merc.
Status
