Capt. Willie
Thread starter- Joined
- Jan 1, 2015
- 34
Update: I installed the missing horizontal supports that run from the front of the Aft deck to the Transom, (see third pic above, for location). Alot of notching for steering rod, etc. and still needs a bit more work, also, I set-up the Port side for EZ removal of gas tank. (It seems Omega installed the tank by sliding it in from the side, and then installed the motor making it impossible to remove tank the same way without pulling the motor.) I tore out the back-to-back seats and seat boxes, (2 sets) but undecided on their replacements.
I still need to replace the vertical plywood, (both sides) seen in same pic just behind the battery, (a temp.battery hook-up location) that supports the front of the Aft deck...decided to watch some NFL, instead of going to Home Depot.
Also, added some plywood to remount the fuel pump, and I mucked out the Bilge box which was mostly wind-blown sand. I plan to built some king of 'battery box', or maybe add a hold-down bracket.
The bow eye needs work, but access is very limited there....any ideas?
I'll try to post more pics after more progress......
