POINT GAP FOR A CHRYSLER 45
tmlavigne
I've got a 1975 Chrysler 45 model 454 and I think that I need to change the points. I only get spark on one cyllinder. I haven't pulled the flywheel off yet but I have a new set of points anyway. What is the gap and is it hard to do? Also, is the flywheel bolt a regular thread or is it reverse threaded and what is the torque? I wish I had a manual, it'd be so much easier...<br /> Cheers to anyone who can help with this info..<br /> Thanks...
scotiany
Re: POINT GAP FOR A CHRYSLER 45
Yeah. That's the same info I have for the 1970 model. Also if you have magneto ignition, set timing at 28 BTDC. If battery ignition, set at 32 BTDC. Source-Seloc Manual. On my engine , the flywheel nut is right hand thread. Do not use any kind of puller with jaws. Use a bolt type puller or you'll be buying a new flywheel.
tmlavigne
Thanks for the info guys. I appreciate it.
