Point or Pre Amp which is better and why on a 75hp 757HA Chrysler
fcross69
I have a cpl of 75hp Chryslers I have a extra distributor with a pre-amp what is the gain by getting away from points. I have heard different reasons why each is better. But I wanna ask the masses what do you all think? I know how to run the extra wire and setup everything I just have heard that a preamp setup starts harder than points but has better response at high rpm's. So please educate me on this thanks.
Frank Acampora
Re: Point or Pre Amp which is better and why on a 75hp 757HA Chrysler
Personally speaking, on engines with a Motorola Magna-Power ignition, I always change to an electronic distributor.
Even though points are just signal and don't carry any treal current like on a battery ignition, they still need to be set to .014. They may corrode and cause problems and when the spring gets old it may lose tension resulting in point bounce.
The electric eye is much more accurate since there is no setting to be done AND the shutter on the shaft will reliable blank the photocell current at the exact same time. The only problem is if the electric eye module goes bad. There is no good way to test it. However on three engines used regularly I have not had an electric eye fail in use. I trust them all to get me there and back.
Long story short: Electronic distributor is better.
Even longer story short: Prestolite non-distrinutor ignition is better and Mercury ignition is best But it takes modifications to use either.
fcross69
Thanks Frank I am going to go down to napa and oder me a timing belt and a spare. May do the swap next weekend. Do you find the pre amp starts better or harder than points or it just a simple win win situation with preamp.
