points to cdi conversion on a 25 hp
doghunter9
I got a 25hp 74 sporter rude that is in excellent shape. but cant get it running smooth, new points condensers, etc.
Now I have a donor motor 84 20hp WITH A GOOD IGNITION SYSTEN CAN I SWAP HESE OUT TO THE 74? Is the cam follower in the way? is the crank shaft the same size to interchange the fly wheel?
thanks
Chinewalker
Re: points to cdi conversion on a 25 hp
No can do. Different size crankshaft taper....
