Hi.i have RK-28 Johnson 40 hp electromatic with generator.ammeter gauge is not showing discharge or charge.is that means that generator needs to be polarized.what are the steps of that .how to test charging components.thanks
Sounds simple,I will try that.i just finished putting generator back after disassembly.brushes are in good condition and points are working.when I connect field terminal to + 12v and ground to housing,generator spins.slowly but spins.is that normal???
Thanks for replies.generator turns out to be fine,as per most tests.sorry joe i don't have wire brush,I used drill @ 2800 and with analog multimeter set to high(30v) connected to battery i got steady 12.5v.no mater if i turned GEN or not.ammeter did not record anything eather.does it mean that my regulator is bad or RPM are too low on drill and its time to invest in wire brush and try again.why ammeter -20 + 20 amps would not move?
