Intermediate Mariner
Thread starter- Joined
- Apr 24, 2010
- 190
Just wanted to share this.
A poor man's (self employed so always broke!) solution for boat building.
Yesterday I was prepping part of my transom and sealed a coat of glass over the inside exposed piece... this is the piece I will tab to hull.
I noticed on another thread someone said to let it get tacky first before applying cloth.
Well, I didn't do anything and the cloth peeled right off the plywood like a candy wrapper, would have never held in a million years!... BUT, I did notice one thing: the cloth peeled right off but the resin stayed on the board! Hmmm. Have used before I know that the resin saturated cloth sticks to existing clean glass like nobody's business. And I had not even prepped the piece with acetone.
So I peeled the glass off the piece of plywood and sanded mostly bare (took awhile). I then prepped good with acetone and simply coated with resin and now man it's on there good! It will not lift or scrape with razor blade, it seems well soaked in - don't want my darn motor falling off you know.
What I found: prep the plywood with acetone first... then apply a sealing coat of resin and let dry, sand, acetone again and you're ready for layers.
I plan to watch the hull tabs and if I see deliamination I will cut it out and go with epoxy.
