FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
I have a large box anchor. Has worked great even in high winds. Toss it overboard, let out rode, drag it a couple of feet till it sets and your done. The only downside is that they are a little more expensive than other anchors.
I too use a danforth style. We moor mainly in sand. I had tried mushroom and they just dragged bottom in a wind. The danforth grips good in the sand. What are you trying to anchor over?
Teamster has the right idea. It is 95% the technique in setting the anchor and plenty of line. Letting out 3 times the amount as the depth of the water should be the shortest you go. If the water is rough you can go up to 7 times the depth of the water. Back up the boat and set the anchor. I use a simply mushroom anchor and it never moves but I am not on tremendously rough waters. Good luck.
X2 ^^^^I also use a 20# dansforth over sand and mud with no problems. I have seen a lot of different types and they all seem to work if used correctly.
I took the Dansforth anchors out of our old Seadoos. I have 100' of line and 10' of chain on each. 1 has always held the 'toon in place, 2 absolutely, positively keep me in place, current, wind, or boat wakes. Both fit in the rope locker of my Tracker Party Barge.
Most any anchor will work, it's all in how you set it. You need a lot of scope out, some where around 3 / 7 times your depth. Then you need to set that by use the power from your motor. I mostly boat on lakes, so a river anchor 18lbs works for me. I sure do like my Trac 35 pontoon power wench with remote control.
Thanks guys - you've been helpfull. I have tried everything with my old mushroom anchor and nothing worked. I have to change. Sully I like that wench -- my back was crying everytime I pulled up anchor. About every 30 minutes.
