Pontoon Cleaning - Is it worth the effort?
martybhawk
Someone said clean, shiney toons will get better speed and mileage. Sounds logical but is the effort and expense worth the return. My toons are 13 yrs old and have pitting below water line. Looking for advice on best way to restore them. I have cleaned them with acid to get crud off.
tashasdaddy
Re: Pontoon Cleaning - Is it worth the effort?
bottom paint.
tashasdaddy
yeah, water line down. with bottom paint especially if keep in the water.
shadetree918
I am working on this also. A daunting task. I too have piting below waterline. I cleaned mine with an aluminum cleaner I found at a semi-trailer shop they use to clean those big tanker trailers. Works great and doesn't choke you to death like muratic acid but will eat your skin if not careful. mixes 70 to 1, so 1 gal should be plenty.
Windykid
Agree with TD, definately paint with bottom paint, also add some anodes.
martybhawk
Should I sand out the pitts first before painting?
Windykid
I would give it a good pressure wash. clean, prep and paint.
jeeperman
nearly impossible to sandout the pitts.
Pressure wash with baking soda in the water.
Then straight water then chemical etch and paint.
studlymandingo
How much pitting do you have? Corrosion on aluminum is like cancer, what you see is likely not all of it. Get all of the white stuff out of the pits and see how deep they are.​
