Hello all. I have a 2006 Bentley Pontoon (200 Cruise) with a 2006 Mercury Bigfoot 60 HP, serial 1B314984. Noticed I had a damaged toggle (party lights switch). Decided to replace the switch. Due to limited access to the wiring under the "dash", I tried to access the switch terminals from the front of the dash by removing (not disconnecting) the adjacent hour meter. At the time, my engine was idling. During removal of the hour meter, the metal ring that secures same contacted both terminals on the hour meter and engine suddenly quit. Now, key accessory position supplies power to all lights. Start position produces no crank and there is no power to tilt/trim switch on shift handle. Battery at 13+ volts.
I don't have a wiring diagram so I can't be sure I'm seeing all the fuses. The ones I am able to view all check ok (continuity). Would appreciate it if a member would help me with fuse/circuit breaker locations and/or any other advice. Thank you!
