Pontoon prop help
dj0443
I have a custom 26 foot triton with a Ls1 380 hp corvette motor. I am running a bravo 3 out drive with 26 p props. My WOT RPMS is 3300.I would like to be at 5500. What prop size do I need. Thank you
captmello
Re: Pontoon prop help
You need to have the motor checked. You have more problems than just the wrong props.
dj0443
Had motor checked.everything is good with motor
steelespike
What is the speed at 3300?If the rpm is correct You would need about a 16" set of props. to get to around 5300 rpm.
steelespike
