Back around July I had the intake manifold crack on my Merc 4.3L when we were loading up at the dock. It was the first time I had the boat out since winterizing it in 2011 and we were still in the wake area when I noticed the bilge was filled with milkshake.
I've done nearly everything I have thought of to do, listed below:
1) New manifold + both gaskets
2) Drained old gas from tank, refilled with non-ethanol fuel - my truck didn't complain in the least about the old gas, probably because I mixed it with Seafoam in 2011.
3) New fuel filter
4) New spark plugs gapped to 0.045 IIRC
5) Tested exhaust manifolds with acetone
6) Verified compression 3 times during various steps of this repair process, all 6 cylinders remained within 10psi of each other
7) Verified timing a couple of times during the repair process (in base timing mode)
8) Rebuilt carburetor
9) Changed oil/ filter three times, water in engine appears to be completely gone. The oil level on dipstick hasn't changed in the last 3 or 4 times I've had the boat out (twice to go fishing and a few more times on land).
As it sits, the motor will not go above ~1500 rpm without stuttering harshly, and flat out will not go above ~1800 rpm at all. Top speed is 10 mph with the trim all the way down. This makes for a bit of difficulty moving to good fishing spots
The only thing I know of that could be left is the fuel pump, but I have no idea how to check it. I'm really not that hyped about verifying yet another thing after 3 months of on/off work on this boat and chasing ghosts each time.
Am I overlooking something here? I don't see how the head could be warped/cracked or the head gaskets be busted since the water in the oil appears to completely gone and the engine has been run many times since I replaced the manifold.
I generally enjoy working on engines, but this is getting absurd.
3) New fuel filter
