poor mans spark plug wire tesater
section8
i was wondering if this was a reliable spark plug wire test!!!!!
start the engine. touch each plug boot.ouch #1 shocked me 2 and 3 did not shock me and #4 shocked me.if you read responses to my compression test thread you might know why. does this mean i burnt out 2 of my coil packs????also when i pulled the plugs smoke only came out of 1 and 4!ha ha ha wa wa wahhh
baxtr
Re: poor mans spark plug wire tesater
you can get cheap inline testers at autoparts stores, I wouldn't use the "bodily harm" method of spark testing :)
hope they aren't fried
Good luck
burroak
Boss, if you can take the current coming out of that spark plug wire, you have bad coils or you are the toughest S.O.B. in the valley.:D
section8
well it shocks ya pretty good but they are still plugged to the plugs and im just touching the back of the boot real quickly. my lawnmower one only shocks me sometimes.thats how i have to stop it because the safety handle/stop bar doesnt work. i just went to napa and they didnt have spark plug testers.thats the only place open today so ill be waiting till tommorrow to test them.how much do the coil packs cost?:(
Frank Acampora
We have all been shocked by accident now and then. It really gives you a thrill. However, you do realize that given the correct circumstances and given the correct path, that voltage can stop your heart. Then, too late, your wife will be calling 911. Not a good idea to do it regularly--no matter how tough you are.
And for you naysayers out there: I know it is the amperage not the voltage that kills, however, all hospitals are set up so their receptacles do not leak even milliamp levels. They do it for a reason.
newbie4life
Ah, this voltage would never hurt you. I've been 'nailed' probably 60-70 times. Never hurt me.
By the way, the voltage wouldn't bother much. I've been zapped about 15-20 times. It doesn't really bother.
For what it's worth... the spark doesn't hurt that bad. I've been hit close to 100 times, and you'd never know it.
Maybe tomorrow, I'll buy a spark tester. :D
jkp1
Doesn't electric shock cure depression? I often get shocked working on engines and always feel better when the job is done.:)
4runneradam
Sounds like the damage is already done! :)
section8
oh man you guys are hilarious! im answering my own question. no this is not a valid way to test plugs/wires! i bought a tester for 11.23 and it says all wires have spark through 'em and my bio-test said 2 werent firing! Hope i helped anyone else who might try this the cheap way!!!
burroak
In the interest of being serious, the following is a reprint of a post by Joe Reeves from another forum. The added point that the quote makes is: the quality of the spark is much more important than the presence of a spark.
" ....the ignition (spark) but apparently by simply using the spark plugs? If so, this is no test as spark will jump the very small plug gap when the plug is in open air BUT it may not jump that gap when under compression.
The spark must be a strong blue lightning like flame.... a real SNAP!
To test the spark properly, you must use a 7/16" gap at cranking speed with the spark plugs removed. You can easily make such a spark tester as follows:
Spark Tester - Home Made
(J. Reeves)
A spark tester can be made with a piece of 1x4 or 1x6, drive a couple nails through it, then bend the pointed ends at a right angle. You can then adjust the gap by simply twisting the nail(s). Solder a spark plug wire to one which you can connect to the spark plug boots, and a ground wire of some kind to the other to connect to the powerhead somewhere.
Using the above, one could easily build a spark tester whereas they could connect 2, 4, 6, or 8 cylinders all at one time. The ground nail being straight up, the others being bent, aimed at the ground nail. A typical 4 cylinder tester follows:
..........X1..........X2
.................X..(grd)
..........X3..........X4
The compression mentioned (10psi difference), low reading on top cylinder, would indiate to me that either the engine has been run with a fouled top carburetor (cylinder running lean), or the ignition being weak on that cylinder.
Let us know about the spark, with it being tested with the 7/16" gap."
baxtr
Very nice re-post Burroak
Scaaty
All I use is a simple wire, 2 big electrical clamps connected to the ends, one around the body, other to ground,..have a couple fresh plugs set at 3/8 gap, 1/4 gap..etc. Crank or yank......
