poor running 67 merc 35 hp
dezl2000
i am having trouble with my engine running at top end or near .the problem is when its running at idle and threw out the power range it is like its not getting enough fuel it runs and then wants to stall and then runs (and so on) i have replaced the plugs and going to run some seafoam in it next does any one know where the fuel filter on this engine is? any help would be apprecited.
Fuzzytbay
Re: poor running 67 merc 35 hp
Check the fuel lines for leaks. Is the prim bulb hard?, Does the motor run better if you squeeze the bulb?
When was the last time the fuel system was checked, ie fuel pump, lines, fuel tank, carb?
