Re: Poor VHF radio performance
The marine VHF antenas come with a standard legnth cable that should not be cut. The fiberglass antenna's are an "omnidirectional" antenna that should be in a verticle position, for optimum performance. If you have cut the antenna cable to shorten it, you should get an "SWR" meter and check the standing wave ratio. The ideal reading is 1.0 to 1.0. If you are getting a reading of over 3.0 to 1.0, you are losing your "match". The higher the first number,(such as 3.0, the less efficient you transceiver is functioning). Unlike the cb type radios, where you can adjust the "SWR" by moving the antenna up and down in it's base setting, the standard marine antennas are fixed, again thru the height of the antenna and the legnth of the cable. <br />You can buy an adjustable antenna for marine VHF use, but you will pay a lot mnore that $40 or $50 bucks for one.<br />One thing you can use to prevent corosion is dielectric grease, the same stuff you use on your spark plug wires and other electrical connections.<br />One last thing. You should NOT transmit on your radio without the antenna being connected. This can be fatal for some circuts in your radio.<br />Some handheld VHF radiso can be used with a fixed mount marine antenna. You will beable to hear much better and your transmission distance will improve. Buttttt....youi are putting out fewer watts on your hand held as compaired to your normal transceiver, which should have the select switch to transmitt putting out 1 watt for close or local use or normal output of 25 watts for distance. Your reception will be the same whether using the 1 or 25 watt mode. One last note. If your "SWR" is even 10.0 to 1.0, you will still be able to hear in a normal fashion, but your transmission distance will be poor.<br /> ...Bob in Calif...
