I have a 2001 200hp Johnson
When I put it into reverse it skips/jumps like it isn't in fully in gear.
If I shift firmly/deliberately it will usually go into gear more fully.
Ive learned from reading on the forum that I should be shifting into gear crisply not gently opps!
We thought that the cable might be stretched or worn out because we couldn't get enough adjustment to have it shift all the way into reverse so I replaced it
It seems to have helped a little but not enough
If we manually move the shift lever into reverse it will go further than the cable will go and it stays in gear without skiping or jumping out of gear
I was reading that the shift rod can be adjusted
Is this something I can do in the boat on a lift?
Or isn't it realistic to do it on the lift
Is there a detailed tutorial/instructions on the procedure to adjust this rod
It sounds like about one rotation would be about correct
Thanks
Jeff
Thanks
Jeff
