I have a 1991 Four Winns 180 Horizon w/4.3 OMC Cobra 170 or 175 horse power. <br /><br />The problem I am haveing started last boating season but was very intermittent. Yesterday was my first day out on the water and it is much worse now.<br /><br />Here is my problem. I have a popping (sounds like a lean misfire) comeing back up through the carb. I do not experience this problem when accellerating from a stop to get on plane or when cruiseing under 3000rpm's. The popping is real bad once I am on plane and I go to full throttle over 3000rpm's. It also seems to do it only when the engine is at normal operating temperature. <br /><br />Also when I experience this problem if I shut the boat off or when it stalls when shifting from reverse or drive into neutral like it sometimes does. I have to let the boat sit almost like letting the engine cool before it will start.<br /><br />I have replaced the spark plugs, distributor cap & rotor, coil and coil wire. I have checked the fuel filter, it was a stone filter, and it appeared to be clean. Any and all input/advise would be much appreciated. Thank You.
