- Joined
- Oct 25, 2011
- 25,292
Use a scarf joint.
Using either 8:1 or 10:1, cut, glue, align and secure the joint until cured. No permanent fastener required.
https://en.m.wikipedia.org/wiki/Scarf_joint
Turn the scarf so that when installed on the boat, water is going past the joint, not into it.
If you screw the chine to the boat, use 1 screw thru the center of the scarf
