jvcoconut
- Joined
- Jun 24, 2007
- 24
Hi,
I posted in Chapparal section, but maybe I can get help here too.
I own a 2005 232 Sunesta 5.0 gxi with a duoprop outdrive and double bimini from bow to stern. I notice when I look at some (not all) deckboats cruising next to me at all speeds, they ride smooth and nice, NO SLAMMING, NO PORPOISING.
I have tried everything.....Full Boat, empty boat, no bimini, both biminis, ice chest, no ice chest...I cannot get it to stop porpoising (even on semi glassy water). I currently trim the outdrive to just before the first line on the trim gauge and have tried all other settings below that and it still wants to porpoise. The only way I get it to stop is to back the throttle off momentarily and re-engage the throttle, then it smooths out for a bit.
WHY CAN"T MY BOAT RIDE LIKE OTHER SIMILIAR DECKBOATS????? The hull is deep enough and the boat is heavy enough, it should cut through chop smoothly and not porpoise on jetski wakes....RIGHT? I talked to my service guy @ Sun Country Marine in Onatario Ca and he rifled off several questions to make sure I was doing everything correctly in the operation of my boat, which he confirmed I was. I asked about trim tabs. He has some customers that installed trim tabs and it took away all porpoising. He also said they don't sit on the boat all that great due to the large swim step, but they can be made to function properly.
I purchased the boat because Chapparal claims to have the "best hull design years running" I think it is a crock of sh*t. I am happy with the boat, except for the ride.
Are trim tabs my answer?
Anyone experience the same problems and fix it with trim tabs?
Which ones will fit under my huge swim step?
Any answers would be appreciated
Hi,
