Port Engine won't start
jhisey
The other day, the port engine would not start. When I turn the key once, the guages move but no sounds (usually I get some beeps). Turn once more and nothing. When I turn the starboard key once, the guages move and I get the beeps. Turn it once more and engine starts.
I pulled the switch panel off and did some electrical testing (I attached a picture too). Each switch has 3 wires, a RED, a YELLOW w/ RED stripe, and a PURPLE w/ WHITE stripe. With key in neutral position, if I put a voltmeter on 2 of the wires, I get 13 volts between A-B and D-E (in picture). When I turn the starboard switch one click, the third wire kicks in and I now see 13 volts between D-F. When I do the same on the port switch, A-C never gets any voltage. Hoping it may simply be the switch, I moved the port wires (ABC) to the starboard switch (position DEF, respectively) but same thing happens. This tells me (in my limited electrical knowledge) the switch is fine but there's a problem (loose wire or something?) down the line. I opened the engine compartment and scoured for loose connections but I have no idea what I'm looking at and all the connections I found I made sure were ok.
It also doesn't matter if the battery switch is set on 1, 2, or ALL; starboard works great, port - nothing. I also let them charge for a few hours in a slip, no difference.
Any suggestions? Or know of any good boat mechanics in the St. Pete / Tiera Verde, FL area?
Don S
Re: Port Engine won't start
Turn the key to the run position and check for voltage on the purple wire.
To properly check voltage there, hook the black wire of your meter to a ground and the red meter lead to the terminal with the pruple wire.
