sprouticus
- Joined
- May 12, 2005
- 208
Well Iboats experts...........it's almost boating season for me again, so once again I find myself back here with more questions.
Last year I put a bigger motor on my boat, from a 70hp to a 90 hp. the new motor was 80lbs heavier, and it left my back end a little low in the water while gowing slow. To compensate for this, recently I have moved the weight around in my boat. I extended the gas lines and put the gas tanks in the bow. Yesterday I bought 18 feet of 2 gauge wire and crimped it on to the 4 gauge wire that used to come off the batery. I pulled the wire through the sides of the boat, which allowed me to move the battery to the bow as well. This is when things got weird.
I rehooked up the battery, and turned the key to see if the engine would turn over (did not use choke as I did not want it to actually start yet..just checking to see if it would work) enigine turned over fine. I pulled the wires a little tighter, so I could get the battery farther forward into the bow, and hooked up the hose and the muffs to the engine. turned the key, expecting the engine to start.............nothing. stood there for a sec wondering what happened, then eventually I decided to see if I could by-pass the solenoid by useing the 2 screw driver trick the engine turned over.....so I thought I found my problem. With all stores being closed for the evening, I started to pack up my tools. when I was ready to go in for the night, I decided to try the key one last time for kicks. The solenoid engaged, and the engine turned over. I turned off the key and tried again......this time nothing. I never touched any wires......never changed anything. So I tried by-passing the solenoid again, and the engine turned over again. I have never heard of a solenoid working intermittedly........but decided this must be my problem.
So today I bought a new solenoid and installed it. (to be honest the marina was closed by the time I got off work..so I went to an automotive place to find a 4 pole solenoid that I could mount on the engine.) I ended up with one made for ford, later model trucks........and also bought a 1000 CCA marine starting battery for my boat, as the 650 CCA that was on there is nearing the end of it's life..and I figured the extra amps could not hurt. I hooked up the new solenoid, expecting all my problems to dissapear. Nope. Once again the only way to turn the engine over was by connecting the battery lead on the solenoid...to the starter lead using 2 old screwdrivers. Now I started to think perhaps the problem was in the extension I made to the battery leads. There were 2, 12 gauge wires hooked up to the battery posts that I thought maybe were not getting a good connection......but I am pretty sure those are for dash instruments. I did not want to take my splice apart to see...I was pretty proud of my crimping and shrink wrap job.............plus I don't see how this could be the problem. Then I thought that maybe the problem was with the ignition.....that would explain why the key wouldn't work, then did, then didn't again. So I took apart my controls...and got a look at the wires. There was a blue wire that wasn't connected to anything, but to be honest...if it was supposed to be and broke off...it was a clean break.........cause it doesn't look like it was ever hooked up to anything. It was starting to get dark so I went in for a flashlight to get a better look.......and of course got a phone call that tied me up till it was pitch black outside. While on the phone I thought maybe while I was pulling the battery leads through the side of the boat I may have disrupted the ignition wires somehow. Then I noticed that the ignition wires look like they had been spliced at some point by a previous owner. I unwrapped the tape to find 5 wires inside. The black and white wires were intact, but there were 3 wires, a green, and I think blue and a red wire that had been taped up. I was going to take the tape off and do the repair properly, but then I thought that the problem might be in the ignition again. I flip flopped a few times, before decideing to come in here and post my findings, hoping someone could help me, I was kinda hoping to get out this weekend.........but it's not looking like it is going to happen. I'm sure it is only a small fix......the issue is finding where the problem is.
BTW.................I have a 90 hp evinrude......and I think it's a 1990. I am still using the controls that came with the boat............the old engine was a 1977 70hp.
sorry for the long read.I didn't want to leave anything out.
thanx for reading and any input you can give me
