We bought a 1994 pontoon last year with a 90 horse evinrude. Owner stated sometimes it will run for 10, 15 minutes and shut down, then wait another 10 minutes and it'd fire back up. The thought ut may be the pack causing this. We bought it anyway and the first time we took it out it did the same thing. Running along and like you pulled the kill switch. We pulled the shifter up, found the wires to the kill switch. Unplugged one and it fired up then wouldnt turn off and you got shocked if you happen to touch a end of the wires. Carfull plugging it back in it would shut down with the key. Im thinking I need a new kill switch. My question is could the problem be in the key switch as well, should i replace both?
