possible shift cable problem
richardson61
have a 93 SeaRay with a 4.3L and Alpha drive. Motor is stalling out when shifting into reverse. Will run in reverse if I baby it just into reverse at idle, but when any throttle is applied it stalls. Also at times will not come out of reverse unless I briskly push into neutral. Forward works just fine. My question is do I have a bad cable or could it be a cable adjustment problem?
Re: possible shift cable problem
Ayuh,... Bad Cable...
richardson61
I replaced the shift cable adjusted according to manual and am still having the same problem is there a trick to adjusting?
fishinpa
Richardson did you replace the cable from the shift box (control) or the cable from the engine to the drive ??????
fish
richardson61
I replaced the cable from the engine to the drive unit
Fishermark
Which manual did you use? Mercruiser service manual or aftermarket (Seloc, etc) manual?
Don S
Did you make sure the shift shaft in the bellhousing moved freely while you had the drive off? How about the one in the outdrive? Did the cable move effortlessly after installing it but before you hooked it up to either end? Was in an OEM or aftermarket cable. I once installed an aftermarket that was stiff right from the beginning. Had to replace it.
richardson61
Got it fixed, was just out of adjustment. The shift cable stud was all the way up the slot moved it down and its working fine now.
bigskiohio
a adjustment does work , my feeling is if cable moves freely it just needs adjusted . wish you would have tried to adjust first or did you?
richardson61
No unfortunatly I had replaced the cable, had tried adjusting the old one with no luck. Probably was just not adjusting it correctly and it was fine, cause old cable appeared to be fine upon inpection but I felt the foot at the end of cablle in the lower unit appeared a little worn.
Ayuh,.. Even worn out cables don't really look or feel bad.....But they're still Junk...
