auscarter12
Thread starter- Joined
- Jun 19, 2015
- 59
I have a leak in my mercruiser pre alpha outdrive. I drained the gear oil, pressure tested, changed out o-rings on the vent and drain plugs, and it still won't hold pressure. I replaced the gear oil and ran the motor last night with the hose and noticed warm exhaust water coming from where my shift shaft is. So this morning I trimmed the drive all the way up and found an oil leak, but I'm not sure if this is the shift shaft seal or what? The attached picture is with the boat in neutral. You can see blue gear oil on the left side of the shaft as well as a little water. I have never replaced a shift shaft seal or any seals on an outdrive for that matter, but I have heard that the shift shaft seal goes out a lot and is easily replaced. Can anyone give me a step by step guide on how to replace this seal, IF that is the seal leaking? Do i need to remove the lower unit from the upper? Remove the propeller? Need any special tools, etc? A step by step guide would really help. I have tried searching online to no avail. Anything will help. Thank you!
