I recently bought a boat with a V6 mercruiser in it. I haven't got it running well yet. The first time I took it out I could only get the engine to 2000rpm even at full throttle when driving the boat, but it revved fine out of gear. The fuel pump seemed small to me for the size of engine, so I have replaced the pump with a larger marine fuel pump. Tried the boat again today and it was improved, but still not running well (but it was improved on the first run). Lag on acceleration and still only 2500rpm max. I also noticed on the vacuum gauge that at idle it was fine, but as soon as it was under load the gauge fell to nearly nothing. It was fine when reving the engine ut of gear, but as soon as it had to work to power the boat the vacuum fell -and it stayed down low until I stopped the boat and the engine was out of gear. I took this to be a vacuum leak, probably between the inlet manifold and the engine (as there is some silicone selent here it makes me think this may have happened before).
Before I take the intake manifold off, which is a biger job than I realised as it involves taking the distributor off as well, does me diagosis sound reasonable or is there anything else that could cause these problems?
