possible water leak from stern drive???
SSBN735
Hello everyone,
First post, so I hope it works.
I have a 1998 bayliner capri with a mercruiser 3.0L and Alpha one drive.
When running water through muffs in the driveway, engine not on, I see water coming from a spot I never noticed before. I am not sure what this area is called so I took a picture (camara was postioned between the stern of the boat and the drive unit looking aft towrds the drive unit). I see that the water is coming out of two small holes back up there behind the speedometer cable?
Please help me understand if there is a problem. I do not see any milky appearance in the drive lube (drained a bit from the screw in plug at the bottom of the drive).
It may be normal. I keep seeing things I haven't seen before and have to determine if they are normal.
Thanks.
smithrock
Re: possible water leak from stern drive???
that's water? looks like oil
SSBN735
It's water. There are no signs of oil leaking anywhere.
SSBN735
Anyone know the answer to this??
Is it too hard to tell the location I am refering to from the picture and desription? I could take more pictures to clearly show where this is if that would help.
Ayuh,... Those are Drains,... Not a Problem...
SSBN735
Thanks Bond-o.
That makes me feel alot better.
I'm surprised I never noticed it before....back to the water!!!
(it's been a great summer with that boat)
PiratePast40
I have a question based on your screen name. You a Bubblehead? I was a fast attack sailor myself. Sunfish - 649 boat out of Charleston.
