Possible y pipe leak
nextboat1
Mercruiser alpha gen II. Upon inspecting a boat that I just purchased I found a small piece of rubber gasket in one of the exhaust holes in the outer transom plate. I think that it might be part of the y pipe gasket that has worked its way to where I found it, but I'm not sure. I have ran the boat on miffs but have not seen any leaks. Is there any further checks that I can do? Could that piece of rubber be from something else?
Fishermark
Re: Possible y pipe leak
Probably the remains of an exhaust shutter.
81 Checkmate
Also if it was the Y-pipe....it would be leaking water inside the bilge!
nextboat1
I haven't had it in the water yet so I can't say if water would leak into the Bilge not. I do not see any water leaking when the boat is running on muffs. The piece is very thin and almost like rubber o ring, so I don't believe that it is the impeller.
81 Checkmate
Do you know when the last time the impeller has been replaced?... If not that would be the first place id look..........If thats good next would be the shutter's (Flapper's as some people refer) in the Y-Pipe.
If it was the Y-Pipe O rings it would leak water inside while running on muffs........FYI - there are 3 O-Rings on the Y-Pipe that fit in a groove with flats on each side of the groove.........If it tore or frayed it would have a hard time getting in the exhaust path.
Fishermark
Well, it wouldn't be the impeller - there is no way the impeller pieces could end up in the exhaust passage. I do agree however that you ought to replace the impeller before going out on the water since you don't know when it was last replaced.
nextboat1
The impeller definitely on the top of my list to get changed. Ill try to get a picture of the mystery piece tonight and post it. Thanks guys!
nextboat1
Here is a picture of the piece of rubber that I pulled out of the exhaust port in the outer transom plate on the starboard side. The picture isn't the best but at least it will give an idea of size. The rubber is kind of rounded but flat on one side. Could this be a piece from and exhaust flapper?
81 Checkmate
Now we know what it looks like.......Looks like the edge of rubber flapper skin to me.
Fishermark.......A peice of the impeller could get into the exhaust passage.....It would have to go thru the block water passage then into the manifold/riser...then in the exhaust. It's posible
nextboat1
That's what I was hoping for. I'm going to try to pull the risers this weekend and see if I can fish out the remaining pieces. Thanks.
Volphin
That's no impeller shred. It IS an exhaust shutter seal. Replace the shutters with the new design. This winter. Go boating for now. No need to pull manis off yet.
nextboat1
Sounds great guys! Thank you for all of your help!
