Took the boat to the lake today, engine fired right up and off we went. Got about half a mile down the lake and the engine sputtered out. Could only get it running by fully choking it and then it would run slow and rough. Got back to the dock and started checking the fuel system. Found that the screw holding the fuel filter casing on was only hand tight, and also my fuel hose connection was a little bit loose and not fully seating. I tightened the fuel filter casing and I cut a small o-ring and put it on the fuel side of the quick connect. Got the boat home, hooked up the muffs and started the engine. Engine ran smooth and strong, I did not have to choke it at all. Ran the engine for about 15 minutes on muffs at different speeds and also put it in gear, everything ran great. Engine was recently serviced before I bought it, I have been on the lake about half a dozen times in the last month with no issues. I plan on going back to the lake sunday to run it again under a load. To me it seems like I may have airbound the fuel system? Any other recommendations from ya'll? Thanks in advance.....
