daveswaves
Ensign
Thread starter- Joined
- Mar 22, 2002
- 901
This came in as a PM, I am posting it here so that the community can see, respond, help, learn etc. Flat Cat 77, reply to this post and lets get you up and running.
how ya doin dave. my name is matt. i have a 500 thunderbolt. inline 4. i bought off a guy who said it ran like a top. i have tested everything and come to the conclusion that the ignition keyswitch is bad. i have juice to everything. but the switch is stuck in the run position no matter what way you turn it. i have a 12V toggle switch two post. and a 12V momentary contact switch push button that also has two posts. i fabbed up a small piece of aluminum to take the place of the old box covor and drilled two holes and fitted the switches in there nicely. do you think that will work instead of just the old keyswitch. this motor was origionally a remote motor. someone has mounted a tiller on it. and there is a control switch coming off of the harness with a keyswitch on it. the ocntrols are not on the motor. i just thought it would give it my own little touch and i already have those switches sitting in my box here at home.
and do you by any change know what wires hook up to the 12V and what two wires go for the ignition switch? there is also a momentary contact switch for the electric choke. if you wnt to help me out let me know and i will snap a few photos so you can see whats up.
I took and put my gas and battery up to the motor. nothing. i took my impact gun like a bump starter on the nut on top of the flywheel and the thing popped off like a champ and ran really great. it has rebuilt carbs on it and new coil my friend told me before i bought it. but once running. my switch was stuck on the on position no matter what position i turned it. so i had to take off the spark plug wires to kill the motor. i had no way to ground the thing out with the switch messed up. lol
