Re: Posted Octane Numbers
Texasmark said:
Now wait a minute Mike. I thought the BTU value of alcohol was lower than gasoline hence lower mpg with ethanol........or am I getting BTU's and octane mixed up again.
Let's see, BTU is heat content.....energy. Octane is the ability to withstand heat/pressure before self exploding (pre-ignition, knocking, pinging). Higher the Octane, the higher the compression tolerance...higher the engine compression can be.....?????? Right?????
Mark
That depends on the compression ration of your engine, the higher the CR the higher octane you require to prevent knocking. 87 octane fuel consits of 87% octane and 13 %heptane, octane strings are better combustible too handle self ignition than the heptane (or other additives to give the same BTU) When high compression ratio engines were build (first in aviation,racing and than for commercial) the need for higher octane fuel was required to prevent the knocking. Lead (TEL)was found to be a good octane booster, but very environment unfriendly, after the lead was banned other octane boosters were required, methyl tertiary butyl ether (MTBE). MTBE unfortunally easily combines itself with water and can cause cancer. Ethanol is a very good octane booster,oxygenetic carbon and as hygroscpic as MTBE but but does not cause cancer..
E10 is unleaded fuel with 10% of ethanol, which is approved for all unleaded engines, E85 is unleaded fuel with 85% ethanol and can only be used for engines which are specially designed for this (flexible fuel vehicles) It is high octane and for high compression ratio engines. Check with your engine manufacturer if you can use it!
Ethanol has a heating value of 76,000 BTU per gallon, which is approximately 30 percent less than gasoline's heating value (which is approximately 109,000 to 119,000 BTU/gal)
Conclusion over all:
If you want to increase the power (HP) of your engine by increasing the octane--you will have to increase your compression ratio otherwise it will not help! and it's loss of $$$ by using a higher octane fuel than the minimum recommended by manufacturer. Because they have the engine designed with a certain compression ratio (common is 8 to 1)
