998cc
Thread starter- Joined
- Mar 30, 2013
- 159
All. This isn't a question, and it may be in the wrong forum.
I walked into the garage this morning and was met with a strong gasoline smell. I immediately opened the garage doors to vent the fumes and went looking for the culprit. What I found was the outside stern of my boat damp from gasoline running out of the vent for fuel tank.
After considering the situation, the cause became clear. The location of both the filler tube and vent tube are located next to each other at the rear of the tank. Combine this with a fairly full fuel tank, and the front of the boat being raised high enough above level to concentrate the fuel at the rear of the tank set the stage for this potential mishap.
The final element was the weather. Yesterday was a very warm day which was enough to expand the fuel/vapor in the tank; this pressure could not vent due to the tank vent fitting being covered by the liquid fuel in the tank. The result was the spill.
The fix was easy. Drain 5 gallons of fuel and lower the trailer jack, so the bow is slightly pitched down.
The danger of this situation was the location of the boat in the garage. The spill was only about 10 feet from the gas water heater.
1972 Gulfstream, MC-1 with GM Inline 6, 250
Russ
Russ
