Sashap
Thread starter- Joined
- May 1, 2016
- 145
ok, latest update...
The other day, while I was waiting for parts I tried starting it. no spark at all. So I tried the timing light and saw nothing no matter where I put it. gave up in frustration. Then the next day tried the timing light and lo and behold there was spark. I changed nothing! But the timing was so out of whack after I replaced the distributor components (EST) all but the module and the distributor body that I figured I must have put it in 180 degrees backwards. It just sputtered, no start but did have spark. Switched it over 180 degrees then just left it.
So, today I put in a new module. At this point, I have a new dist cap, new rotor, new pickup coil, new module. And guess what? no spark...nothing, Only thing left is the fricking coil. I did the recommended Ohmmeter tests and it seems to test ok. I get .7ohms where it says .4 but a mechanic says anything under 1 is ok.
Help! I am so lost...
It's going to warm up weather wise and I would love to try the boat out as I have never had it over about 10mph due to this whole episode.
What do I do to thoroughly go over everything to verify spark? What would cause this on again, off again spark?
I don't mind putting in a coil, it's just that I half doubt it would be that after everything else I have tried. It seems ever since I took out the old dead tach that this no spark thing started happening. Something to do with the safety lanyard? How do I check that?
