Power head switch
Jack Daniels
Will a 1986 FORCE 85 hp power head fit on my 1983 FORCE unit? Thanks
Frank Acampora
Re: Power head switch
Most definitely! Mechanically, everything is the same.
If the '86 has quick connect ignition components,there is nothing to change. If the '86 has a terminal board on the electronic mounting board, it is easier to use the whole ignition system. Are you sure it is an '83? I thought the Chrysler name was used until '84.
Jack Daniels
Yep positive its an 83 was registered and dated, the last chrysler version of the FORCE from what i understand. So what you saying is that all my ingition components will be able to be switched to the 86 rebuilt head? Frank your the man.
