WhiskeyGun
Thread starter- Joined
- Jun 30, 2016
- 10
First off, I am fairly new to boating and boat engines. I bought a used 1996 BlueWave with a 1990 140hp Johnson motor (Model#: j140tlese). It ran great for 2 years up until past few months.
I started getting power loss whereas I try to throttle up and the engine doesn't respond. It has gotten worse with each trip. The RPM's don't build up quick at all. It starts up fine at the first turn of the key. However, when I first noticed the issue, the motor was quieter like a 4 stroke. It idled ok and smooth just quiet. It would even run normal on the first route to my destination. After throttling down for whatever reason and then trying to throttle up, I would barely get a response. Since then it has gotten worse as the motor eventually stalls. Everyone I've talked to said check the fuel system as it seemed to them it was starving for fuel.
So here is what I did so far:
1. Changed all fuel lines, filter, and bulb up to the fuel pump (fuel lines were old and flaking, lots of black specs in filter). However, there was no change in bad behavior.
2. Bypassed main fuel tank, by just putting the fuel hose in a regular gas can. The boat's tone was better, it sounded like a 2 stroke. Most of the power seemed to have returned. Only issue was no hole shot whatsoever, it was slow to build up speed but would eventually get on plane and run WOT/turn like a champ. At that point I suspected problem with fuel tank.
3. To eliminate components of the fuel tank, I got a regular 5 gal boat tank, and installed the anti-siphon valve on it and regular 3/8 hose as pickup. It ran very badly like before after that. Therefore, I suspected the anti-siphon valve.
4. Removed the valve, and the behavior of the engine returned to almost normal, but still no hole shot whatsoever. So my mind turns to weak fuel pump, in which it can't open up the valve and/or losing vacuum.
5. Removed VRO fuel pump (oil side already bypassed by prev owner) and inspected it. Upon removal, I noticed a little bit of gas coming out of the pulse tube which I think is abnormal. Is that abnormal? I took a peek at the inside of the pump, and all diaphragms and o-rings looked ok. In fact, I didn't see any apparent gas in the air motor, which is the only way I think the gas could get into the pulse tube. Maybe it was just sucking it all out. Anyways, I want to know what y'all's thoughts are?
A kit for this thing runs $125 which may be a bust. I've been looking into replacing the pump with a non-vro one. I've see them going for $45-$125. My thoughts are why not just buy the non-vro pump instead of kit at that price. I've talked to a few of the sellers and they all say it should work, but I've yet to find anyone with experience swapping it on my spec motor. The pump descriptions say it should work for up to 140hp 4 cylinder engines.
I am a bit confused as I read some people need two of them in series for the larger motors. I've read that is just for 6 cylinder motors, and others say you should have the series for 125hp+.
Basically, what I want to do is replace the VRO pump (p/n 5007423) with something like this:
https://www.amazon.com/Johnson-Evin...dp/B007I8ZHEG?ie=UTF8&ref_=pe_623860_70668520
Also, am I on the right track? Did anyone have a similar experience?
