chrisambrico
Thread starter- Joined
- Jun 25, 2020
- 3
I am the very proud owner of a 99 Stamas 31 Express with twin 350 Mags. Developed a power loss that is fuel related. Normally, I would just change the fuel pump, but I have seen many posts of others with a similar problem and had replaced the pump, cooler and regulator with no success. With twin engines it offers an easy comparison. I was losing power in the port motor over 2800-3000 rpm. After some basic evaluation, felt it was a fuel concern. Check fuel pressure and found it to be 25 psi at idle, and 32 psi with vacuum line disconnected. Took it out and once under load it stayed pretty steady at 30 psi which appears to be the spec. Being a little confused, I compared to the "good" starboard engine. Fuel pressure was 40 psi at idle and over 50 psi with vacuum line disconnected. I would normally consider this a fuel pump issue, but again, based on some posts I have read, that seems to be the one thing that never works. Unfortunately, never seem to get to conclusion and many posts are 10 years old. Any help is appreciated. thanks in advance.
