power loss
mobgod
Re: power loss
Can anyone help me out on the correct way I can test my power packs ? All I have is a ohm meter I don't have a neon tester like the book is telling me so what is the best way to test ?
mobgod
Re: power loss
Ok further reading looks like to test my power packs all I need to do is disconnect number 6 and 11 set my meter to high and note the reading but what am I looking for does the boat need to be running or just the power on ect.....
mobgod
Re: power loss
ok guys need help again with this.Today what was done replaced the stator and still no difference i still have full throttle but after she comes off plain i lose the power she will drop from 5k to 4 than bounce between 3 and 4 than finally stay at 3. Also today i did test the power packs diodies per the book with a ohm meter they both were good,also did test the timer base with a ohm meter and that turned out good can someone plz tell me wat the heck this can be now. Should i just replace the power packs or coils or both lost now on this problem.
mobgod
Re: power loss
Thanks to all for the help sorry for the run around with this but it's fixed. Had a little piece of hose or plastic in the fuel jet of the carb.... Going to post a picture in a bit.
