Power Pack black/yellow wire 84 100 hp E100WTLCRS
edfishing2
Guys,
When people mention disconnecting the black/yellow wire at the powerpack does this mean using pin removal tool to pull pin out of Amphenol connector? Or removing the wire at the terminal strip?
Just trying to learn where for reference. I think my kill system is fine.
Re: Power Pack black/yellow wire 84 100 hp E100WTLCRS
Unplug the big red wireing harness connector that will remove the key switch ground that could kill your spark. You will have to crank the engine with a remote starter......to do a spark test.
Sometimes its not easy to unhook the black yellow because there in multiple pin connectors.
