Power pack or coil?
Bert
I have a 1999 150 Johnson that is running on 5 cylinders. I've swaped coils and wires, plugs and nothing changes. Would a power pack be going bad on just 1 cylinder.
R.Johnson
Re: Power pack or coil?
Have you done a spark test on all 6 cylinders, that you know one cylinder is not firing?
Bert
Yes,I have done a spark test and get no fire. As stated, I have change coil, wires, and plugs. I'm getting no fire to that cylinder.
JUSTINTIME
u need to see if u are getting volts to that coil
nect test ohms of stator and triggers
clint
Most likely if coil has no power in that cylinder it could be a bad ground between the coil and engine block. Very common problem. Check all ground wires clean and retest. Usually a power pack problem will carry problems to another cylinder. Good Luck!
Clint d:)
Bert
There is no power going to that side of the coil from the power pack lead.
JUSTINTIME
bad power pack then if u have no power
u need to test the stator and trigger and power pack first
bigredfish69
i have a 1995 johnson 25 , i am not getting any spark i have changed both plugs, i have compression and getting gas. i am looking to test power pack. can anyone help me???? desperately needs to go fishing...
Joe Reeves
Bert..... Having retired some years before that engine came into existence, I'm somewhat unfamliar with the design of the components circuitry, and hopefully you've tested the spark by having the s/plugs removed and testing the spark at cranking speed using some kind of tester whereas you can set a 7/16" gap. If not, do so.
The spark should jump that gap with a strong blue lightning like flame.... a real SNAP! Does it. If so.......
As you've explained above you've pretty well eliminated the coils as being suspect. Now, to seperate the timer base from the powerpack as being suspect, I'd suggest the following.
The timer base wires to the powerpack (if memory serves me correctly) are color coded to the related cylinder, depending on which bank as: Blue = 1 or 2, Purple = 3 or 4, Green = 5 or 6.
Whichever cylinder you're having no spark on, switch those wires accordingly.
Now, if you have spark on the coil that was not previously firing, suspect the sensor (timing base).
If no change in whatever coil was faulty (same coil has no spark), suspect the powerpack.
However..... The problem you're encountering could also be due to a pin/socket being pushed back too far in its rubber plug, a broken or frayed wire at these same plugs, something of that nature. Let us know what you find.
Bert
8)Thanks for everyones help, it was the powerpack. I put a CDI powerpack on a got fire a all leads, a much stronger blue flame on the spark tester. Motor started much quicker also. Thanks again to all.
sort of off topic here, but close.
I was trying to hook up a tach for my 140 HP Johnson which is a 79 model , and is a V4 Sea Horse.
I was told to hook up my grey tach wire to the negative coil. Which coil would I use and which side? I have four coil packs and I can't tell where to hook it up to it at?
Any ideas?
Thanks
