Overnighter20
Thread starter- Joined
- Nov 8, 2009
- 33
I had a noticable miss in a 1983 Johnson 200hp v6 I recently bought, so I just replaced all 6 ignition coils, as well as new plugs, and fired her up. It is better, but still has a miss, so I proceeded to pull one plug wire at a time and see if I could find a cyclinder that maybe was not firing. Turns out, #5 cylinder makes no difference in running with or without the plug wire on. I ran out of daylight, but my plan is to move the coil to another cylinder and see if the problem moves with it when I get a chance. Is this the best way to test the coil?
Also, I have read that the power pack could be the culprit of misfiring on 1 cylinder on a v6, and that it's always better to replace both power packs at the same time. Is this true? If so, why both?
Any ideas, or better testing info would be much appreciated.
Thanks
Frank
Thanks
Frank
