Hello Everyone,
I am having difficulty with a 1975 Evinrude 135hp after about 2k RPMs. I have recently bought this motor so I have no history with it. This was my first in the water run with it:
Cold starting is a little difficult. Starts, shuts off. Once warm after about 2 or 3 minutes the motor starts and runs at an idle and warm-up position. It will go into gear and maintain low rpm under a load. When I increase to half throttle the motor start to "sputter." Increase throttle more and the motor shuts off. Bring the throttle back and it easily starts back up and idles.
Playing with the throttle, back and forth quickly, i did get the motor to come up to full RPM, the boat to plane, and stay at High rpms for a couple of minutes. The motor ran smoothly. After backing off the throttle it went back to the sputter and was unable to duplicte the good running condition again
Things I have done:
Water Pump has been Changed
Carbs have been rebuilt (Soaked in Kerosene for 2 days, used HP Air and all orifices looked clear)
New gas at a 50:1 ration (tried 2 different tanks)
Pulled each plug wire off while running at an Idle and part throttle, each dropped in RPM and picked back up when reconnected.
Compression is 115-120psi all cylinders
What I had noticed:
The fuel tank throttle ball seemed to be very stiff, more than what I have seen with other motors.
When i disconnected the fuel line hose from the tank, I got a really good spraying. Under a lot of pressure.
The spark plugs are NGK BUHXW-1. Came with the motor, the champion plug listed in the manual is not available anymore according to the champion website. In fact champion does not list a plug for the motor.
Took the fuel pumo apart, noticed some almost steel wool like wire in the valves. Diaphram, springs, look ok.
Changed the fuel pump out with a known good one. Though again I can't find a sierra rebuild kit or a sierra replacement one for this motor, not listed. so I am guessing the one I am using will work. 18-7820 which is for a 140 hp V-4.
Haven't had the boat back in the water yet, been raining.
Any thoughts or suggestions?
Thanks In Advance!
John
Things I have done:
What I had noticed:
Thanks In Advance!
John
