Power steering (i assume) makes it hard to keep straight at slow speeds.
scooper77515
Volvo 4.3 GL with power steering. It reminds me of an old Ford power steering system. Loose with play in the first inch or so of steering, then you feel the power kick in and it turns quickly.
I have to go through railroad bridges with 12' spaces between the poles, and I am having to fight it going back and forth with the steering wheel.
Is this normal? If not, what can I do to tighten it up?
Fine at high speeds, but I am having to overcompensate back and forth to keep it straight when going slow.
burp
Re: Power steering (i assume) makes it hard to keep straight at slow speeds.
Slow speed wander is pretty much "the nature of the beast". It's not caused by the power steering but planing hulls and ones tendency to over correct when making course corrections.
EddiePetty
...the more pronounded the Vee, the more severe the low speed wander.
Smartabs all but cured our V-20 from wandering, though we do not have power steering.
Decrease the extent and frequency of your steering corrections and allow the hull to more-or-less self-center. Fewer, slower and smaller corrections, though hard to resist larger steering inputs, will also reduce the wander.
Tail_Gunner
As above i am about to name the boat LOST SOUL...Low speed wander is a pain
HT32BSX115
This subject always comes up.....
Slow speed "wander" of a rear-drive, V-bottom boat is a characteristic of "Rear Drive", "V-bottom" boats.
Except for ACTUAL loose steering components, low speed wandering is not affected appreciably by Smart tabs, Stupid Tabs, cockpit adjustable tabs, multiple prop drives, multiple drives, Witch Doctors, Marvel Mystery Oil, Slick-50, Sea-Foam, or or other snake oils etc.
Increasing your speed slightly will reduce the wandering. Increasing more will eliminate it. (your keel becomes MORE effective)
Just deal with it!
Cheers,
Rick
robjen1019
I don't know, the tornado properly inserted in the carb might give just enough boost to keep it from wandering.
EddiePetty
Hummmm...I stopped wandering when the XO started treating me better!!!:D
scooper77515
Oh, thanks guys! :cool:
New-to-me boat, and I just assumed it had to do with the power steering.
Previous boat was a jet, 14.5' and did it, but not as difficult to correct. Or maybe after 3 years I just got used to it.
John_S
Smart tabs reduced it on my boat. Having people sit it the bow vs the stearn basicly eliminates it for me. This is at 1000rpms, not idle.
Simoniz
Rick
So drive through your gap with posts 12'' either side at 30mph and you'll be just fine! :D
Brewman61
Ensign
I have heard that power steering somehow aggravates the situation. Not sure myself why, but my boat wanders and it does have power steering.
Anyway, time at the helm will help- the tendency is to overcompensate and that aggravates the zig zagging. I'm finding myself doing waaaayyy less steering correction now than when I first got the boat.
scooper77515
I will try less correction and see if that helps. Gotta overcome that natural gut feeling to steer more...
generator12
I'll chime in on the Smart Tabs response. A pair helped me considerably with the same problem on a 17.5 foot Four Winns with power steering. The additional drag on both port and starboard reduced the zig-zag to negligible on my rig. And I wouldn't even have tried to go through a 12" clearance before I installed them -it was that bad.
scooper77515
There is more than 12" clearance. It is about 4 feet on both sides to play with. So I guess that comes out to like a 16' gap between the pilings.
Still, they are solid concrete, and I don't really want to bounce off of them...:eek:
whitney
+1 Smart tabs took away 90% of my annoying low speed wander (and 90% of the choppy ride on my 18 footer). Love them, best $120 I have spent on the boat.
scooper77515
What size Smart Tabs would I need for my boat?
Sounds like it will solve many of my problems.
They don't interfere with the tie down straps, do they?
EDIT--Oh, nevermind. It is all listed out on their website.
EDIT#2--$215 at West Marine in stock :D
