Re: power steering leak
I have a Uflex that did /dose the same thing. First time I had it looked at Uflex replaced the head. 1 find the leak. Could be the seals in the back of the unit behind the dash board. The pressure during temp change can blow the seals> Now that i have them all replaced, I crack the fill port at the wheel. It wheeps a little but not like it did. If it grinds when you turn the wheel, there could be something in the pump, or needs more fluid, air in the lines. These things are a crap shoot. I got the best info from uflex, and seastar. The vent cap/fill port i feel dose not allow for the pressure the system builds as the boat heats up and cools down. Pressure purges the expanding fluid out of that port resulting in a yellow knee and slick floors.
