power steering line thread size
Status
Not open for further replies.
PowerAddict
Hi guys,
Does anyone know the thread size for a power steering line?
Its a 1994 mercruiser 7.4 liter. The line comes from the pump and goes to the rack (looking for the side that goes into the rack, not the pump). The thread looks too fine to be regular pipe thread? is it compression fitting thread?
Thanks guys.
Bt Doctur
Re: power steering line thread size
Do you mean the hi pressure or the low pressure side? Hi is from pump to rack, low is from rack to cooler to pump.
Hi guys,
Thanks guys.
Unable to tell you the sizes but if it is to replce without buying Merc, most hydraulic hose shops can make some up. In an old post achris mentions many have gone to the new style using quick connects, just need to find newer modle engine and use parts identified for it.
http://forums.iboats.com/mercruiser...bers-compatibility-power-steering-582184.html
PowerAddict
It is the Hi Pressure line.
I don't need a new line, I need a tap for the rack to chase the threads.
Ayuh,.... That Ain't gonna happen,...
It's an inverted flare fittin', pretty much exactly like American automobiles use,...
There's a "Seat" at the bottom, 'n no room for a tap,...
PowerAddict
I know what you mean Bond-o. But its' like, the 2nd thread. I'm fairly certain I can get an end-tap in there to get whatever is causing my issue.
I'm fairly certain its a 16 x 1.5 but I can't find any confirmation of that. or a -6an
How about taking your line to Lowes/Home Depot and see if you can find a nut which will screw on?
PowerAddict
well, If I would have been smart enough to take the line off before I left it last week, I would. But, the boat is 64 miles from where I live at farm where I'm working on it, so I don't want to drive all the way out there just to get the line. I'd like to get the tap and then head out there to fix it. Know what I mean? I shoulda taken it off before I left last time - don't know why I didn't. :facepalm:
84EdH
I have a high pressure hose for a merc 5.7 that is from a 1995 350 mag alpha. I have no idea if its same size as you need, but I can confirm this:
big end, to the pump, (I presume) is SAE inverted flare 5/8x18, small end to rack SAE inverted flare 7/16X24. maybe you can parts search the hose for your 7.4, and see if it is same number for 5.7 ? hope this helps!
PowerAddict
AWESOME! Thanks, I'll check!
Could not find the size anywhere. Only found that the Merc fitting is propritary for the quick connects, and the same ram is used on about all boats these days. I have an old ram in my shop with quick connects which I used a dial caliper on the threads and eye balled the threads.
Small
0.5121 (13mm) by 24 threads per inch
Large
0.6230 (15.8mm) by 17 (could be 18) threads per inch
Bt Doctur
Before you go crazy, I might have the fittings from an old hose or someone here might have a bad hose that you could remove the fitting,
file in 4 slots to act as cutters and thread that in to chase the thread.
Ayuh,... Or he could go to an Automotive Parts House, 'n buy a brake line fittin', 'n do that,...
PowerAddict
I just want to say I think its pretty awesome you guys are trying so hard to help me with this problem. I do hope one day there's something that I can contribute for you all.
What do you mean my file 4 slots? like, flat spots on the threads? Every 90 degeres?
Volphin
You might try a thread file if you can find one...
Ayuh,.... Turn the fittin' into a tap/ thread chaser,...
PowerAddict
Just so everyone knows It was a 14 x 1.25 (Metric!) I actually found a tap for it too and was able to get the fitting in. Thanks everyone.
Volphin
Great job! And thanks for posting the size! Someone, someday will need it I'm sure.
bstanz1
Machinist here and this is what I would do.
And cut the slots at a "cutting angle" with a little clearance in front and you will have a custom chasing die that is only good for limited chasing but should be exactly what you need.
Status
