power steering problem
pcrg28328
I have a 20' stingray cc with 4.3 merc and alpha 1 gen 2 outdrive. While steering I have to constantly pull my steering wheel to the right just to keep straight. It feels like it is slipping inside about 1 inch at a time. Every minute or so I have to reach the the left of the steering wheel and start pulling to the right again steadily slipping to the right. If I let the boat go on its own it will drive in a leftward direction. Any ideas?
Re: power steering problem
Ayuh,.... Adjust the torque tab, mounted in the cav-plate, above the prop,....
If the cable 'n helm are actually slippin',... Replace 'em Both, as a kit...
achris
More fish than mountain goat
Sorry Bill, no trim tab on those drives...
OP. What steering system do you have? Hydraulic or cable?
pcrg28328
I will assume it is hydraulic since it runs off of a power steering pump and the steering wheel never finds a stopping point. It will turn forever. I se what could be a cable and is very stiff. It runs from the helm to the steering.
Under Helm.
At steering.
achris
Nope, that's a rotary cable steering system. If it never finds a stopping point, the helm unit is bad, likely a stripped tooth...
pcrg28328
Thanks. Are they generic or vessel specific? How much should they cost?
achris
Generic... and you'll need to get the cable out and read the length written on it... The cable and helm are usually sold together...
Cost? a shed load in Australia... Much cheaper in your country (I assume you're in USA)...
