Power steering pump
GasCan II
Hello guys;
I need a little help finding the power steering pump part number for a 1997 Mercruiser 5.7 LX Bravo 2 engine number
OK 147937.
Thanks for any help.
The complete power steering part number is 16792A39 and will get you the hole pump assembly
http://www.mercruiserparts.com/bam/subassembly/31865/2344/250
It is a regular Saginaw PS pump used on most GM cars and trucks. If you replace just the pump, make sure to keep the HP fitting which is where the line attaches to. Don't use the new one that comes with the new pump, it does not supply enough pressure
