Blood & Curses
Thread starter- Joined
- Jul 29, 2009
- 13
Afternoon Gentlefolks,
I have a 1992 Mariner 115 with the single ram tilt unit. I was running across the bay the other day and the trim gave out. Pushing the engine up against the stop. I had to use the manual release to raise it up for trailering, as I thought it was just low on fluid and I could repair it at home. When I got home I noticed that the motor will run (you can hear it) in both up and down, however it will not raise the motor only lower it when I raise it by hand with the manual release. I have tried filling and refilling the reservoir, however still no up. The ram is leaking however I have not had this problem in the past, just need to fill it every once in a while. Is it possible that the seals in the ram are just gone, or am I overlooking something obvious?
