power tilt on v-4 1982
baiwan
How much oil should I add in the power tilt. I found the plug, but don't know at what position of the tilt to fill up. Is there a drain plug as well and where is it?
Any advice shall be appreciated.
emdsapmgr
Re: power tilt on v-4 1982
The oil needs to be filled level to the bottom of the fill hole. Run the trim up and down a few times, then check again to be sure it stays at the full level. The system self-bleeds when the trim is run up and down a few times.
baiwan
Thanks a lot. I am doing it now and will be in touch.
baiwan
Thanks. I was playing with the power tilt and found that at different positions the level in the tank is different, I entered the forum to ask and read the answer, so now I will add up oil the proper way.
There even is a hint - you can't reach the plug with the motor down.
