Power Tilt Trim Problem DF 140
kirt123
I have a 2003 Suzuki DF140. The tilt/trim is starting to act up. If I start let it sit a day or so without using it, The tilt and trim will be very slow until I fully trim it down and let the trim motor fun frreely once is gets at the bottom or I can just go up all the way ant let it run for a few seconds. Then the unit seems to work fine until I wait a few hours to days. It seems like it is getting quite worse as time goes on. I The electric motor seems very slow itself when I first start using it. I checked the wiring and terminals on the battery for loose connections. Sometimes I have to hit the switch a couple times before it will start moving but I can hear the solenoid clicking. Like I said these problems only happen when there is longer period of nonoperation. Like 6 hours to a few days. Do you think this would be motor related? I am thinking it may be the brushes in the motor. Can you remove the motor without taking off the pump cylinder assembly, it says to do this in the manual but does not look like it is totally necessary. Thanks
