power tilt
recently installed a evinrude power tilt on my 1972-78 50 hp the instructions seem to indicate reusing the tilt pin and the manual tilt lock this seems counter productive any body used to these older motor supply there input
1730V
Re: power tilt
Yes, you need to leave the tilt (trim pin) in. Just set it to the lowest point you want your engine to go.
The manual tilt lock can be deployed as insurance. Power tilts can sometimes "drift" down.
In either case, neither the trim pin or tilt lock interfere with the tilt only units.
Re: power tilt
Confused If The Tilt Lock Is In Place How Will The Motor Raise
Understand About The Pin For Lowest Setting But Would Have To Leave In Release Always So I Could Raise As Needed Is This Correct???? Dont Want To Do This Manualy Looks Like The Cylinder Would Hold It Good Enough For Reverse
1730V
Re: power tilt
You're right, I confused the tilt lock with the "Trailer" lock which locks the engine up.
The tilt lock MUST be disengaged for the tilt to work. Yes, the tilt unit will hold it in reverse.
Sorry for the confusion.
