FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
Hi guys. Alpha 1 gen 1 outdrive. The drive creeps down fairly quickly and I continually have to bump it back up. It will actually creep down on the trailer just by gravity. Do I have a check valve in the hydraulic system bad?
I would see this as the cylinders needing new seals. Fluid is leaking past the piston in the cylinder. Rebuild the cylinders is fairly cheap and easy enough
Possibly. But the valve is inside the pump body. If it is the cause, you need to either have enough knowledge of hydraulic pumps to be able to strip it and repair it, or you need to replace the pump.
Try resealing the cylinders first and if that doesn't fix it, it's the pump...
